When changing and EGR valve
LS1Tech Premium Sponsor
If I recall correctly on most, if not all, of the EGR codes the MIL (malfunction indicator light) will turn off after 3 consecutive ignition cycles that the diagnostic runs and doesn't fail. Then the history code is cleared after 40 cycles of the same without failing.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
