Anyone know a way to settle down a PLX Wide band?
Old 02-01-2010, 09:54 AM
LS1-450's Avatar
Default Anyone know a way to settle down a PLX Wide band?
The after decimal digits change way too quickly & I'd like to dampen the dead band. How is this done? Thank-you
Old 02-01-2010, 10:15 AM
Moderator
jimmyblue's Avatar
On my LM-1 there are "filter" options (instantaneous, or
average over N samples). It's something you have to
"push" using the LMConfig program, from the laptop..
Look for something like this in the PC-interface software
for the PLX?
Old 02-01-2010, 10:20 AM
LS1-450's Avatar
for the PLX?
OK, I'll have a look. Am not sure there is an interface other than what can be done to the wide band logging/tunning through my EFILive software. Thanks for the reply.
Old 02-01-2010, 10:28 AM
Frost's Avatar
I think it's a fixed ouput on the PLX. You just get it 'how it is'.
Old 02-01-2010, 11:16 AM
LS1-450's Avatar
Yah, it is. I just went through everything in the tuning software & there is no way to do anything other than calibrate the output of the PLX based to correct voltage drop.
Thanks again guys. I appreciate the replies.
Old 02-01-2010, 11:19 AM
shoemike's Avatar
If you have V2 you can set the AD filter in the device.
You can edit the PID expression to compensate as well.
Old 02-02-2010, 05:22 AM
LS1-450's Avatar
Thanks, unfortuneately I have a V1.2.
