Have an AEM wideband need cable for tuner to use??
Old 02-05-2010, 10:33 PM
vipvegas's Avatar
Default Have an AEM wideband need cable for tuner to use??
My tuner is going to tune my car SD as my maf tune now is having major issues and throwing a p0101. He said I need a cable for him to hook up to my wideband. It has been two years I dont remember any other cable. Where can I obtain the cable needed?
Thanks
Old 02-06-2010, 02:58 PM
shoemike's Avatar
Is this installed in the car now?
He should'nt need any cable if it is because the sensor has it's own harness to the gauge and the power and ground harness has the analog and serial wires in it.
Old 02-06-2010, 03:04 PM
OutToWinPAHC's Avatar
That or he should have his own wideband meter that he can use with your sensor, that or just remove the sensor and install his/
Old 02-06-2010, 03:54 PM
vipvegas's Avatar
It has been installed for about two years so I guess I need to go check and see if the wire is stuffed in pillar pod.
Tuner doesnt have a wideband, but said he had proper software to communicate or whatever else is needed
Old 02-06-2010, 04:06 PM
Ehh, I think I would seek a more equipped tuner. One with a good working dyno, wideband, and history. Tuning can cost a little or alot but the difference could mean the world.
I think he is looking for the Data logger cable.
Old 02-06-2010, 04:15 PM
vipvegas's Avatar
Tuner is very reputable. I dont doubt him. He has done many cars I know of. The dyno is a local shops dyno he uses usually to tune at. Its not his shop. Not sure what cable I will call him and see.
