Can you swap front and rear O2 sensors to get rid of code P0133?
Old 02-06-2010, 10:38 AM
Black98T/A's Avatar
Default Can you swap front and rear O2 sensors to get rid of code P0133?
I have a new LS6 crate engine in my Trans Am and had pcmforless tune out the rear O2's for no cats. I have straight pipes in place of the cats and I'm getting a P0133-Oxygen Sensor Circuit Slow Response (Bank1, Sensor1)
* The oxygen sensor is faulty
* The wiring to the sensor is broken / frayed
* There is an exhaust leak
I checked under there and there is a tiny exhaust leak around the pipe so Im going to take it back to the exhaust guy on monday but if the sensor is bad will swapping them fix this?
Old 02-06-2010, 12:03 PM
shoemike's Avatar
They are all the same sensor just different length of wires, so yes you can swap
the rear O2's to the front.
Old 02-06-2010, 01:17 PM
Black98T/A's Avatar
So if the rear ones are just dummies now it won't matter if they are bad right?
Old 02-06-2010, 02:47 PM
shoemike's Avatar
They are just for diagnostics and set the MIL.
The fronts are what the PCM references for fueling. (LTFT&STFT)
If the MIL was turned off in the tune then you can remove them from the harness.
Old 02-06-2010, 02:49 PM
Black98T/A's Avatar
Well i switched them disconnected the battery and still have a SES light on.
Old 02-06-2010, 08:49 PM
poconojoe's Avatar
Are you running long tubes?
Old 02-10-2010, 09:49 AM
Black98T/A's Avatar
No stock 2002 F-body LS1 exhaust manifolds and stock y pipe with straight pipes in place of the cats(for now)
After switching I drove the car about 40 miles then the light went out then came back on about 40 miles later and hasn't been out since.
I'm looking at some new sensors and I saw the NGK heated 4 wire ones 21528 and 21544 $104.06 for the pair at Amazon.com
Old 02-10-2010, 11:36 AM
Black98T/A's Avatar
Or should I get part # 21537 as they are longer so when I put longtubes on soon I won't need extensions?
Old 02-10-2010, 05:58 PM
SS SLP2's Avatar
Your exhaust leak may be your problem if it is in front of or near the oxygen sensor.
IF buying new ones I suggest the ones for the rear on the carvette as I think the heat range is/may be better and the wires are longer so when you go LT, I do not rember the # they may be the # you are looking at now .
yep just plug the rear holes
Johnny
Old 02-10-2010, 08:15 PM
Black98T/A's Avatar
Johnny
That's what I'm thinking too... the leak is near the sensor and I havent gotten it fixed yet because I'm waiting on a muffler I just ordered and I was going to do both in one shot but I might take it by there tomorrow and see if he can fix the leak first.
The rear corvette ones are # 21537 and I'll probably get those. They are $53.44 each
Quick Reply: Can you swap front and rear O2 sensors to get rid of code P0133?
