need a noise diagnosed
Old 02-10-2010, 12:21 PM
KL20's Avatar
Default need a noise diagnosed
symptoms are a fluttering sound like an exhaust leak that seems to be on driver's side. it only happens when i let off the gas and coast, and doesn't increase/decrease with RPM's. it's not an exhaust leak as far as i can tell because i've been all under the car and can't hear it at idle or even manually giving throttle under the hood. what could be my options on what to look at next or even what's causing it? thanks in advance, it's driving me nuts.
Old 02-10-2010, 12:47 PM
Blackhawk777's Avatar
Valve flutter maybe?? I could be wrong though.
Old 02-10-2010, 01:11 PM
Joshiedoom's Avatar
Unplug your evap purge solenoid and see if it stops doing it
Old 02-10-2010, 07:47 PM
KL20's Avatar
I'll see what those options turn up. This could help some, it started the second I picked up my car from discount tire after getting new front tread.
Old 02-10-2010, 10:37 PM
That's why I just pull the wheels off and take them in. I don't trust the tire monkeys with my car whatsoever. they did that **** to a truck I had once and fucked up the pitman arm.
