Old 05-18-2016, 06:07 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Electrical Guides
Print Wikipost
need help ,The battery does not charging
Old 02-16-2010, 06:43 PM
PONTIAC SLP's Avatar
Default need help ,The battery does not charging
Hi , when i switch on the car the alternator shows 13 voltege when it comes warm 10-11 voltege and the battery not charging and die , this is the third time i bought a new battery , do u think guys the issue from cables or ground connections ?
Old 02-17-2010, 04:12 AM
any one here ?
Old 02-17-2010, 08:22 PM
fptransport's Avatar
have you checked the alternator? take it to get check or you can check it with a voltemeter...
Old 02-17-2010, 08:59 PM
97camaross's Avatar
YA have the alternator checked buy an actual shop(not autozone or any parts store) It sounds like an alternator prob...
Old 02-18-2010, 05:23 AM
SSdimension's Avatar
It does sound like an alternator problem. First make sure you that all the connections are good and intact. Second make sure none of the cables are corrosive or partially gone. Dont go to autozone to get it check. Anybody can get hired there and dont know what the hell they are doing and just tell you crap. Take it to a shop. (NOT ADVICE, DO AT YOUR OWN RISK) I always unpluged the battery (The RED SIDE)and if it turns off then its the alternator because its not giving out a charge or possibly the cables. If it does stay on then its giving charge just something is off between the alternator plugs to the battery. Double check everything. Let us know if you fixed or need some advice and let us know how you fixed it and what it was. Antonio.
Old 02-19-2010, 09:55 AM
thank you guys for help , in monday i'll buy a used Denali alternator
Old 02-20-2010, 02:16 PM
Q8-TECH's Avatar
check for unwanted voltage drop across the wires to and from the alternator.
Old 02-22-2010, 01:19 PM
updated today I bought a new Alternator from uni point , when i switch on the car the voltege above 13 when i'm walking around the alternator needle of the gauge is playing ! whats wrong ? maybe a bad belt or what ?
Old 02-22-2010, 01:35 PM
...with cheese.
Armageddon's Avatar
Your alternator voltage should read right at 14v idle. Are you using a multimeter on the alternator or are you just going by what the gauge in the car says?
Old 02-22-2010, 02:19 PM
both and i have auto meter volts gauge , when my pigtail has interrupted i replaced it with 98 camaro pigtail ?
Old 02-22-2010, 04:22 PM
...with cheese.
Armageddon's Avatar
I don't understand what you're saying. If you've got a factory cluster and an autometer gauge for voltage they're more than likely tapped into the same signal wire. You could be getting an incorrect signal voltage. If you take a multimeter/volt-tester and check voltage across your alternator while the car is running obviously you'll be getting the most accurate reading.
If you've replaced the alternator and the voltage numbers you get are still unstable the belt would be my next guess. Does it squeal or make any noise at any point during the cars heat cycle? Check the belt tension and check for cracks.
Buy me a ticket to Kuwait and I'll come fix your car
Old 02-22-2010, 09:29 PM
Q8-TECH's Avatar
okay first off we cant possibly tell you if you have a bad belt or not. you should be able to tell that just by looking at the belt. make shure you tensioner is in spec. and also use a DVOM to check the voltage and not the gauge
Old 02-23-2010, 12:03 AM
Any battery icons poping in your instrument cluster? Might also be a ground.
Old 02-23-2010, 12:04 AM
Im not sure but is the connection to the starter good? You might never know. Let us know what happended. Antonio.
Old 02-25-2010, 04:51 AM
So did you figure it out?? Let us know?? There might be someone out there that has the same problem and I would like to know...
Old 02-25-2010, 05:18 AM
I replaced all cables and ground connections , the new ( uni point ) alternator insn't working good and causing a short when i launch , I bought used 2005 denali alternator yesterday and today i'll install it and i'll let u know .
Old 02-27-2010, 05:08 AM
installed the denali alternator and the same ! after that i installed my 3 alternators on my cousin 2000 camaro and all of them working good above 14 voltege , what the hell is going there on my car ? I replaced all cables , pigtail , belt and now i have 4 alternators and all of them working good , I waste all my money on the alternators !!
Old 02-27-2010, 08:42 AM
BOA279's Avatar
Ok...this is not a hard system. First, does the car still die since you have replaced all of these things? Take your multimeter and check voltage on the battery (red meter wire to positive and black to negative). Start the car and check the voltage at the battery the same way. With the car running you should be about 13.5-14vdc. If this is true then the alternator, belt, wires and voltage regulator are good. If something is wrong with this step try checking voltage right at the alternator wires. If its good here then you need to look at the wires between the alternator and battery.
Also, check to make sure the engine is grounded really good. Set your meter to "ohms" and put one meter wire an unpainted part of the engine and the other lead on the negative battery post. You should have something close to "0"
Try these checks and let us know what you found
