P107 Code
Old 02-21-2010, 12:42 PM
danbrazda's Avatar
Default P107 Code
Getting this code after installing Catch Can and removing AIR system. Code reads "Manifold Absolute Pressure Sensor Circuit- low input".What did I F-Up?
Old 02-21-2010, 02:08 PM
danbrazda's Avatar
So I fixed it-sort of, at least no SES anymore. I had removed the electrical connector in the pic below and disconnected the two small hoses attached to it thinking it was all a part of the AIR system and since I pulled the AIR Pump it wouldn't be needed anymore. Well, when I put the relay (or whatever it is) back the way it was- no SES light.
If not a part of the AIR system, what is it?
Quick Reply: P107 Code
