Misfire
I just found a bad pin connector in my PCM, it was causing 4 cylinders not to fire on my drivers side.
Weed out the coil(s) and fuel injectors first by swapping with a good one. Switch a spark plug wire with another one and definitely change/swap that spark plug to weed that out too. Possibly a leaky fuel injector, so you can always swap that one with another one.
Really, all that checking is free to do.
