Need Torque Specs for BMR LCA's....
If you're using a torque wrench on the head of the bolt it's 80 ft/lbs, nut end is 60 ft/lbs. I would think if you over torque the bolts you could cause some binding with the LCA. JMO http://www.ls1.com/rearsuspensionsto...ifications.htm
Al
Al
