answer needed asap. attn foff667
Old 02-26-2010, 10:53 AM
TransWS6Am's Avatar
Default answer needed asap. attn foff667
if a write entire was performed on my 02 vcm with a random 99 file is my vcm id still the same? or does it wirte the vcm id also. i found a shop who has a tech 2 and can flash my vin/os back to my vcm, but its not gonna be worth it to me if my hptuners is still not gonna work. gotta be at the shop at 10:00 pacific today. so if someone knows the answer pleasee let me know
Old 02-26-2010, 01:04 PM
LS1TECH Sponsor
foff667's Avatar
Yes it would change the vcm id number to whatever that random file had in it.
Old 02-26-2010, 01:07 PM
CalEditor's Avatar
The OSID is the Operating System Number
The VCM ID is the Electronic Serial Number (ESN) of the VCM/PCM.
This is a Hardware ID number and as far as I know it you can't change it unless you do some fancy work with the memory chip when it is out of the PCM.
Old 02-26-2010, 01:15 PM
TransWS6Am's Avatar
yup just figured that out. just got back from the shop. oh well atleast i have my own vin/os back on my vcm. as i didnt have my stock file saved on my laptop. looks like there is no other way around it but to buy 2 more credits so i can get back in my vcm. now is there gonna be any problem now that i have my own vin/os on my vcm but the 99 vcm id? any discount codes floating around for some hp tuners credits?
Old 02-26-2010, 01:21 PM
TransWS6Am's Avatar
ok this is odd im looking at the licencing window on hpt and it shows my correct vin but for serial is says yyyyyyyy. am i gonna be good to licences this
Old 02-26-2010, 01:41 PM
TransWS6Am's Avatar
well great i got the credits and it wont let me licence the computer now. it doesnt show the option to licence when i try to. now what do i do
Old 02-26-2010, 02:05 PM
2xLS1's Avatar
It is going to require a year/model license now.
Old 02-26-2010, 02:16 PM
TransWS6Am's Avatar
yeah did a search. just got the year model licence. i guess this whole thing is over now.damn $300 later. atleast i can edit my friends 01's now. does this mean i can do 01 trucks also or just camaros/and ta's
Old 02-26-2010, 05:43 PM
2xLS1's Avatar
Just F-bodies.
Old 02-26-2010, 06:25 PM
LS1TECH Sponsor
foff667's Avatar
I was always under the impression a write entire will change this.
Old 02-27-2010, 06:21 AM
poconojoe's Avatar
Not according to the guy who wrote the software, I normaly use. I even emailed him to be sure, after your post.
Old 02-27-2010, 09:44 AM
LS1TECH Sponsor
foff667's Avatar
I just asked the guy who wrote our software and it does, the vcm id number is in the same block as the vin which gets overwritten during write entire on LS1's.
Old 03-01-2010, 02:33 PM
CalEditor's Avatar
If that was the case you could program 10000 cars with 1 hpt lisence
Old 03-01-2010, 04:24 PM
Frost's Avatar
No, you are misunderstanding how the license works (or you are referring to using other PCM flashing warez). Those 10,000 cars will all have different ID's. In order to make them them same as the one file you did license, you have to license them (so that you can write to them).
Old 03-01-2010, 04:26 PM
LS1TECH Sponsor
foff667's Avatar
Correct, our software can detect if you don't have a license for the vcm id number in the pcm you are writing to and will ask you to license the vcm id on the pcm if you don't have a license for it.
Old 03-11-2010, 06:25 AM
CalEditor's Avatar
This was Programmed with a Tech II and the same PCM was used.
Old 03-11-2010, 01:30 PM
Frost's Avatar
You quoted him him saying that about their software and you are talking about a TechII...
Can a TechII even modify the VCM ID though?
Old 05-19-2010, 01:40 PM
CalEditor's Avatar
I have been playing with the VCM ID in bin files. I have changed the VCM ID in a bin and then flashed the bin into the PCM and read it back out. So far the VCM ID doesn't change to the new one even on a Write Entire or Forced Full Program
Old 03-18-2011, 05:18 PM
RamAirRocket's Avatar
No, from what I have been digging, a Tech2 cannot change the VCM ID.
Has anyone confirmed, 100% confirmed, that you can change the VCM ID by flashing a PCM with a file from another PCM?
I am trying with Winflash and CANNOT change the VCM ID, why is this a problem? I put a 99 OS in my 0411 PCM and it blanked my VCM ID and I cannot get it back at all. The VIN is written differently. Is it an issue for me? Not directly, but I am concerned why it did it.
I am betting that no one can change the VCM ID unless they have a command that specifically changes it.
If anyone has unlimited in HPT and an 0411 and would be willing to test this, please let me know.
Old 03-18-2011, 05:26 PM
Frost's Avatar
Yes, doing a write entire is really a full binary flashing; the VCM ID will be whatever is in the file that you flash on (HPTuners). I'm 100% sure because I do it.
You can't do it with winflash.
Quick Reply: answer needed asap. attn foff667
