answer needed asap. attn foff667
The VCM ID is the Electronic Serial Number (ESN) of the VCM/PCM.
This is a Hardware ID number and as far as I know it you can't change it unless you do some fancy work with the memory chip when it is out of the PCM.
Has anyone confirmed, 100% confirmed, that you can change the VCM ID by flashing a PCM with a file from another PCM?
I am trying with Winflash and CANNOT change the VCM ID, why is this a problem? I put a 99 OS in my 0411 PCM and it blanked my VCM ID and I cannot get it back at all. The VIN is written differently. Is it an issue for me? Not directly, but I am concerned why it did it.
I am betting that no one can change the VCM ID unless they have a command that specifically changes it.
If anyone has unlimited in HPT and an 0411 and would be willing to test this, please let me know.
You can't do it with winflash.
