Help! Rear alignment issues
Here's my set-up: Recently installed Granatelli lowering springs, Bilsteins all around, BMR boxed lower control arms, bolt-on relocation brackets, BMR adjustible panhard bar and Suspenion techniques heavy duty front anti-sway bar.
Here's my problem(s): The left rear tire is about 1/2 inch to the wheel well while the right rear is about twice that. When I turn hard to the right I can hear what sounds like the rear left tire rubbing on something. Perhaps the panhard bar might have something to do with it but i thought the panhard bar was strictly a lateral movement thing. Perhaps the lower control arm relocation brackets might be causing the rear axle to be off-kilter? Or perhaps both are contributing to the problem? At times the car doesn't seem to "track" front to rear properly. Any thoughts?
