Bad Plug caused Havoc!
I was having some trouble with the SS. I was getting the feared Check Engine Light 3 times in a month. Never got around to scanning it, just reset via battery cable removal. I assumed it was the rear O2 sensor as I have a 3" catted down pipe and used the spark plug extender to move the sensor out away from pipe. Well.............. After driving through some nasty *** wet snow storm and slush, I got a "Service Traction Control" warning, flashing engine light, TC light, I had a light show on the dashboard!There was a roar or rough noise coming from engine/tire area??? Next day, the traction control light went away, but the car was running crappy, on 7 cylinders! I took it out and ran it hard and it finally ran better, for about a day and a half. Today, the Service Traction Control warning was back several times and engine was running like crap. Finally got a steady check engine light and read the code. PO301, Misfire faulty, cylinder1. Ok, I wait for engine to cool, go out after dinner and pull the wire and plug on #1 cylinder (glad it was the front side of engine). Well holly crap Batman!! Plug was super fouled because a piece of the ceramic insulator on the center electrode had broken off, probably some time ago. That plug couldn't fire a chain saw. I brought plug to Local Advance Auto and to my surprise, I got a new one for free. I guess Delco guarentees them for 3 years. Anyway, I replace the plug and she is running like a champ again, no codes, no Traction Control Warning. I am wondering if the misfire had anything to do with the traction control warning mesaage, or was it unrelated and I am going to see the warning again???
i had something simular happen, was coming off the highway and all of a sudden it started running like **** and the check engine light came on. so i pulled into one of the parts stors and read the code (misfire on cylinder 1) so i pulled the plug and there was a little piece of carbon stuck in the spark plug, so i cleaned it , put it back in and was on my way.
Just for hahas I pulled the front plugs just to see how they were burning. Not surprised, the DOD plugs had a coating of deposits on them, as opposed to the non DOD plugs which looked very clean.
Well 24 hours and 60 miles later and all is still well, no codes or lights, engine is smoother then its been in a while, milage seems to be improved, we'll knock on some wood and see what happens. This spring or summer, the other 7 plugs are getting replaced when I put in the LS6 intake, but thats another Post.
