torque arm install hardware question?
Old 03-05-2010, 01:48 PM
conde'strans's Avatar
Default torque arm install hardware question?
So I bought a Spohn torque arm from someone here and now have a question about the hardware needed to install it. The rear of the TA uses 2 long bolts so my question is: Will the stock long bolts work on this aftermarket TA or do I have to buy them as well(so I can order them from Spohn already)? I don't wanna wait till the 10 bolt comes off and then to find out I'm missing hardware! Someone please enlighten me! Thanks in advance!
Old 03-05-2010, 03:27 PM
blackbullet#1's Avatar
Default bolts
UMI says don't use the washers with your stock bolts. if you decide 2 use the stock ones put them in from the top (threads down) and i would say atleast make sure you get a full nut!
Old 03-05-2010, 10:23 PM
So you're saying the stock bolts might not be long enough then for the aftermarket TA? Anybody out there use the stock long bolts for an aftermarket TA? If not so I can already order them from some vendor.
Old 03-06-2010, 05:37 AM
Default bolts
yes they are a little short.The ta you bought is made out of thicker material.
spohn sells the bolts u need they allso go in from the top threads down nutt on bottom
Old 03-06-2010, 10:26 AM
dlk1950's Avatar
UMI also has the bolts.
Old 03-06-2010, 11:00 AM
The hell with it I'm just gonna order them already. I didn't wanna have to wait on the damn bolts to come in to do the install but oh well! Thanks guys!
