Anything interchangeable from a pontiac GTO into a 4th gen?
it's definitely possible...but would require a lot of modifications to the mounting points, plumbing for the HVAC, and electrical work to get everything to function in the center, such as the hazards and what not.
...and some inteligent fabs sills .
If you have a plastic welder and know how to use and understand plastic fabrication , vinyl/leather wrapping to re-finish the area you fabbed , can read wire diagrams and have a good grasp of how to cross wire things that shouldnt be there using OEM harnesses or improvise where u have to , you would be off to a very good start . You can make anything work really ...were about to start a 2010 camaro dash and center console going in a 72 monte carlo .
I would avoid this like the plaugue if youve never done any of the above or dont wanna spend lots of $$$$ for a shop to do it .
