Headers very close to oil filter, Problem?
Old 03-16-2010, 04:06 PM
MacGyver's Avatar
Default Headers very close to oil filter, Problem?
Recently purchased a 98 SS that has FLP longtube headers on it. Did an oil change today and the previous owner was using a stock size oil filter. I like to use a long filter (Mobil 1 206) After installing the new oil filter it's VERY close to my headers. Probably about 1/8th inch between the header and the filter.
Anyone else have this issue or think that it will be a problem with the heat from the header?
Thanks for any input
Old 03-16-2010, 04:21 PM
Z28_LT1's Avatar
I don't have that issue, but if its that close, maybe you should stick to the shorter filter.
Old 03-16-2010, 06:55 PM
Hard Core Z28's Avatar
FLP headers where known for being close to the headers. put something around the filter like a larger spark plug wire boots.
Quick Reply: Headers very close to oil filter, Problem?
