Flywheel choice on 3000lb Stock-Internal car???
Old 03-17-2010, 08:07 PM
NSSANE02's Avatar
Default Flywheel choice on 3000lb Stock-Internal car???
I'm about to replace my OZ-700 with a new Level 3 Monster and I'm looking for opinions on the flywheel. I have the 18 lb. one right now with the Tex and it has worked well with a best of 1.60 60' on DR's at 3300lbs. I'm looking into possibly going with the 28lb steel FW this time and I'm wondering if the heavier flywheel will help out enough with the launch to compensate for the slightly slower top end. If it matters, the car is now around 3000 lbs, running on slicks, and launching off a 2-step @ 6200rpm. Opinions?
Old 03-17-2010, 08:08 PM
Hard Core Z28's Avatar
Stick with the lightweight alum.
Old 03-17-2010, 08:21 PM
NSSANE02's Avatar
The 18lb flywheel is chromemoly, I won't be going with aluminum.
Old 03-18-2010, 11:17 AM
Gforce Engineering's Avatar
I'd go with the 18lb flywheel from Monster. Less rotational mass is allways a good thing at the track.
Thanks
Chris
Old 03-18-2010, 01:01 PM
NSSANE02's Avatar
Guess I'll stick with that one then, thanks.
