Oil Pressure- Drops under hard acceleration
Old 03-19-2010, 02:07 PM
nasty98z28's Avatar
Default Oil Pressure- Drops under hard acceleration
Oil Pressure gauge drops under hard acceleration in first and 2nd gear. I'm told could be low oil, oil sending unit and or sensor or oil pump. Has anyone else experienced this, and know of a fix to it?
Old 03-19-2010, 02:27 PM
LS6427's Avatar
If your low on oil it'll do that for sure. You did check that already, right?
Old 03-19-2010, 02:54 PM
the_merv's Avatar
Put oil in it..
Old 03-19-2010, 03:42 PM
samson_420's Avatar
Could be anything from low oil to high oil clearances within the engine.
Old 03-19-2010, 09:41 PM
Juicy J's Avatar
If his oil is low enough to be doing that, then the low oil light should be coming on.
Old 03-19-2010, 09:49 PM
mklinger's Avatar
Could be a bad o-ring on the pick up tube. Seen that before.
Old 03-20-2010, 05:04 PM
nasty98z28's Avatar
I checked the oil, it was low so I put some in. That solved the problem not enough oil to pump under acceleration.
Quick Reply: Oil Pressure- Drops under hard acceleration
