So apparently my PCM/harness was originally for a 6 speed....
because I don't have a blue 33 TCC wire attached to the pin. In fact, there never was because it is plugged. The blue 32 (clutch pedal position switch signal) had a wire that is gone. But the goof ball that made my harness put a 4L60e plug on it. Good news is there is a wire coming from red 42 (TCC enable circuit) so that makes me think I will still be ok after I get a wire shoved in that blue 33 pin. Sooo how does a fella go about doing that?
Who made yer harness?
Thanks novaman! Mine has a tranny plug and everything is wrapped up with loom and appeared nicely done. I really don't know if I have all the right wires inside the loom. Is there a couple of things I can check for to make sure all will be well. Will the pcm support the auto just fine? I think/hope the goof ball did a little work on the pcm ie vats delete, minor tuning and hopefully threw in some shift points, but that is entirely speculation.
