Need pt# for 7-pin wiring harness connector to coil packs.
Old 03-21-2010, 04:21 PM
99Bluz28's Avatar
Question Need pt# for 7-pin wiring harness connector to coil packs.
I need the correct, and current pt# for this 7-pin wiring harness (weather pack) connector that goes to the coil packs.
Thanks!
Old 03-22-2010, 01:19 PM
99Bluz28's Avatar
Anybody...?
How about a good alternative, I need a new one since the snap lock broke off on on this piece on the Drivers side and it keeps coming loose.
Thanks!
Old 03-22-2010, 01:34 PM
NBM-LS1's Avatar
Zip ties my friend! If you can wait till wednesday I will have the part number for you. I have a catalog at the shop that has all gm and foreign connectors in it.
Old 03-22-2010, 01:48 PM
99Bluz28's Avatar
Thank you !
Old 03-22-2010, 03:13 PM
99Bluz28's Avatar
Question
I think this will work just fine, what do you think?
Metripack Refill Kit 8 Cavity pt#106205
http://www.casperselectronics.com/st...roducts_id=931
Old 03-23-2010, 07:16 PM
Pocket's Avatar
No dice, the black connectors dont fit
$12
http://www.eficonnection.com/eficonn..._pigtails.aspx
Old 03-23-2010, 07:30 PM
99Bluz28's Avatar
Smile
You are "The Man"!
Thank You!
Quick Reply: Need pt# for 7-pin wiring harness connector to coil packs.
