a/c/heat wont blow out vents and ses lights on
There is a three way vacuum tee by the air conditioning evaporator core box on the firewall that always breaks. They are under three bucks and most parts stores have them in the Help section. They are under five dollars from the dealership also if you want a GM one. Your map code is probably also from the vacuum leak.
