Sponsored by: CARiD
What is this???
Old Mar 20, 2010 | 06:29 PM
alaninin's Avatar
Default What is this???
What is this and wear does the vacuum line with the eletrical tape hook up too?????
Old Mar 20, 2010 | 06:49 PM
alaninin's Avatar
Would anybody online know what it is?? It sits on the drivers side above the coil packs, by the intake manifold
Old Mar 20, 2010 | 08:27 PM
LS6427's Avatar
Its just sitting, not attached to anything?
Old Mar 20, 2010 | 10:16 PM
biggb1783's Avatar
vacuum line for the evap purge valve. (almost positive)
g/l.
Old Mar 20, 2010 | 10:40 PM
joshp14's Avatar
biggb1873 is not correct.
That line heads to the AIR shut off valve. Your car doesnt seem to have it in place by looking at your picture The AIR system must be removed on your car. The solenoid that the vacuum line is connected to in that picture controls vacuum to the shut off valve. There should be 2 vacuum lines connected to that solenoid.
I would unplug the electrical connection to the solenoid and remove that one vacuum line that is taped up. If you remove the solenoid from the car, be sure to plug the other vacuum line otherwise you will have a vacuum leak.
BTW, there arent any vacuum lines that go to the purge valve...except for the large one that runs from the valve itself to the intake manifold.
Old Mar 20, 2010 | 10:45 PM
biggb1783's Avatar
Sorry, i dont have one in the driveway to go look at, LOL.....
Old Mar 20, 2010 | 10:47 PM
joshp14's Avatar
Me either. Mines 30 miles away in storage. Helps when you work on this stuff daily.
Old Mar 21, 2010 | 08:26 AM
alaninin's Avatar
Yes there is two lines going to it and one line is connectedand the other short line goes to nothing and is taped off. My car has air and it is working fine. Where does the short line connect to??Thank you for your help.
Old Mar 21, 2010 | 11:24 AM
alaninin's Avatar
Thanks for all the help so far but I am still not sure where this connects to.
Old Mar 21, 2010 | 06:09 PM
alaninin's Avatar
Still need some help on where this connects to.
Old Mar 21, 2010 | 10:27 PM
joshp14's Avatar
As I said, it connects to the shut off valve for the secondary AIR injection system. By looking at your picture, your car is missing this valve. Someone removed it and taped off that vacuum line.
