2001 Trans Am build sheet
Old 03-22-2010, 10:57 PM
T/A Rumbler's Avatar
Default 2001 Trans Am build sheet
Where in the car is the build sheet located? I bought a 2001 Trans Am today with a Ram Air hood and the car is totally stock as far as I can tell. The engine bay looks like it just came off the assembly line. Not a scratch or ding anywhere on the car and the interior is absolutely mint. I wanted to look at the build sheet to find out the options installed. Any help is appreciated, thanks...
Old 03-23-2010, 09:26 AM
cabolew's Avatar
You can start with the RPO codes on the drivers door.
Check out this link for more info: http://www.phs-online.com/services.htm
I had a reproduction window sticker made for mine. I think I started through PHS link above.
Old 03-23-2010, 01:08 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Most of the build sheets were thrown away by the dealer.
I got luck and still have the one for my '00 Z28
Old 03-23-2010, 11:34 PM
It appears the RPO codes on the drivers door have been removed or they are located somewhere else in the car and I have searched with no luck. Not sure why someone would remove the sticker unless they were trying to sell it as a WS6. The carfax report is clean with no problems, so I am not too worried about it. I am pretty sure it is not a WS6, but a Trans Am with a Ram Air hood. I was trying to find out if it had a2:73 or 3:23 rear. I guess I will try that link phs-online it looks like they can send me the info I need with the VIN number......thanks for the help!
Old 04-06-2010, 12:15 PM
Egg1456's Avatar
http://www.compnine.com/vid.php
Old 10-26-2011, 09:34 PM
john_remkus's Avatar
I'm in the same situation with sticker in the door jam taken off. Did you ever have any luck verifying it's a WS6 or finding the build sheet?
Old 10-27-2011, 07:22 AM
Bird Man's Avatar
Try the vehicle ID #
Old 11-25-2011, 08:55 AM
I tried running the VIN on one of those decoder websites, and that little guy didn't verify it she was a WS6 or not (buzzkill). Now I've talked to some people about the minor differences between the two, and this is what I've found. Again just by word of mouth.
1) WS6 has power steering cooler in the upper radiator hose and the T/A doesn't.
2) Panhard arm is a little thicker on WS6s (dont know by how much)
3) WS6 has slightly better shocks (supposedly bilstein?)
4) The functional Ram Air hood <---Bitchen!
5) supposedly the gap between the core mount and airbox is slightly taller as well.
I'm just trying make sure that I don't improperly badge or run a car without the deserved badging. If ya'll know some of these differences are not actual differences or a little more detail let me know. Any input would be righteous.
Old 11-25-2011, 09:14 AM
82cetuner's Avatar
you got a few things backwards.
ws6 cars have DECARBON shocks not, and regular T/As can have
the simplest way to tell is look at the door codes it should have WS6 somewhere on it thats where the name WS6 comes from it will be listed with all the other PRO codes
Old 11-25-2011, 10:56 AM
yeah, that sticker in the door jam has been removed (shady).
Just to clear things up said that all WS6s have DECARBON shocks, and that T/As might have bilstein?
Old 11-26-2011, 05:26 PM
justatunedport305's Avatar
PHS doesn't do build sheets for newer Pontiacs.
Start here: https://ls1tech.com/forums/special-e...w-sticker.html
I ordered my build sheet through Allied Vaughn, sent a copy of that to PHS and got my reproduction window sticker.
Old 11-26-2011, 05:29 PM
Not all WS6 cars came with DECARBONS...
Old 11-27-2011, 04:48 PM
JohnnyBs98WS6Rag's Avatar
Other minor corrections:
The PS cooler became optional on non-WS6 cars in later years, I think '98-'99 were the only years that ONLY the WS6s got the coolers.
No difference in the panhard arm.
Midway through the '00 production, the WS6 suspension was "de-contented" compared to the standard T/A suspension. I believe the only difference was the sway bars and 17" rims after mid '00. Shocks and springs were the same.
Old 11-27-2011, 08:12 PM
That's MISTER MODERATOR
Paul Bell's Avatar
The compnine website is gone.
Write down your VIN. Go to ANY GM parts counter. Give it to the parts guy and ask for a RPO printout. This usually takes up to two minutes to do. It's usually free of charge.
This RPO printout will be for your car. It will list everything installed on the car, all options, all items, all trim codes.
If your car is a WS6, it'll be listed in this printout. If it's not a WS6, WS6 will not be in the list.
You can look up your codes here: http://www.rpocodes.com/
OR search for a specific RPO here: http://www.gm-trucks.com/rpo-code-lookup/
Old 11-30-2011, 03:10 PM
update: that guy at the stealership printed it out. yeah it's a WS6. sweet
Old 11-30-2011, 07:51 PM
Paul Bell's Avatar
Quick Reply: 2001 Trans Am build sheet
