Temp. Sensor voltages
should be either 12v or 5v supply.. you would see that at all times, tells you the computer is powering the sensor.. but to check to se if the sensor is not bad, you need to measure its resistance, and that scale i do not have for you... but if its the same as the lt1 sensor and iat sensor, room temperature is around 2.2 kohm.
Finally fixed it.. Went thru 2 sensors (one from NAPA and one from autozone) And those would not work.. Had to get one from a GM dealer(AC Delco). Works great now.
