Difficult startup after a reflash??
Old 03-28-2010, 08:55 PM
That's what she said...
TheBlurLS1's Avatar
Default Difficult startup after a reflash??
I have been tuning my friends turbo Camaro (Sluggish on here) lately and it's been giving us some trouble. The car will run/start just fine. We will do some data logging, I will make MINOR changes to VE, spark, etc, and try to start the car back up.
The car will crank up for about 2 seconds, then die, over and over. Eventually, it will finally regain it's senses, fire up, and run like nothing happened, but this usually takes 10-15 tries. When it's doing this, I can re-write the previous tune that was in the car, and it doesn't help at all.
I'm using HPTuners 3-bar SD custom OS, and it's a 2002 car/PCM.
Does anyone know what might be causing this?
Old 03-28-2010, 11:23 PM
Frost's Avatar
IAT heat soak is a common issue.
