Water Pump Pressed in Outlet Fitting
So I was trying to tweak the angle on the waterpump outlet pipe and it popped out the press fit between the steal pipe and water pump. It looks like it was epoxied in from the factory. It is a press fit but not a very tight fit.
Has any one had any luck resecuring the outlet pipe after it was removed? I was thinking use some JB weld and knock it back in.
Loctite has a product for that.. Here's the number that I have:680.
A pdf tech sheet...
http://www.fiberoptics4sale.com/pdf/...spec-sheet.pdf
A pdf tech sheet...
