caliper bracket to abutment thread size
Old 04-03-2010, 03:10 PM
Bowtie_Aaron's Avatar
Default caliper bracket to abutment thread size
Hey guys,
Im finishing up an LS1 Fbody rear disk swap on my chevelle, and i need to know what the thread size is for the rear caliper bracket to pad abutment.
this is the part that bolts to the backing plate and houses the pads, then the caliper fastens to that.
is it an M10x1.5? i tried a 7/16-14 bolt, and it fits sloppy, so im assuming that its metric, and possibly M10?
it would be the thread size for the two outer most holes...
thanks
aaron
Old 04-04-2010, 11:11 AM
Save the manuals!
wssix99's Avatar
Its a metric, high strength, washer head, hex bolt. You can get them from the dealer. Given that these bolts take all of the stress of braking, I wouldn't trust any other hardware.
While you have that off, you can to go RMS Auto Parts and get new rubber boots for the parking brake levers. (They are the only supplier any one has been able to find.)
Old 04-04-2010, 11:26 AM
cool,
you dont know the thread size though do you?
thanks man!
aaron
Old 04-04-2010, 01:48 PM
Save the manuals!
wssix99's Avatar
On the late model LS1 F-Body, the bolt specs are:
For the REAR -
GM Part Number: 10229606 (Rear caliper bracket bolt)
Description: Metric Heavy Hex Flange Screw
Measurement: M12 X 28 X 1.75
Manufacturer: BBC Fastners
Ultimate Strength: 100 kgf/mm2
Yield Strength: 90 kgf/mm2
If anyone looks at this later and wants the FRONT (They are different)-
GM Part Number: 18023646 (Front caliper bracket bolt)
Description: Metric Hex Cap Screw
Measurement: M12 X 35 X 1.75
Manufacturer: MNP Manufacturing Corp.
Old 04-04-2010, 02:25 PM
Thanks guys!!!
Aaron
Old 10-27-2013, 10:16 AM
Jeff Smith's Avatar
Do Fastenal store have it?
For the REAR -
Old 10-27-2013, 02:55 PM
Save the manuals!
wssix99's Avatar
Not when I looked. You can get them from any GM dealership and they aren't too expensive. (They are on par for what Fastenal would gouge you for on a special bolt.)
Quick Reply: caliper bracket to abutment thread size
