LT1 Diff carriers
Old 04-04-2010, 09:34 AM
LSCamaroDan's Avatar
Default LT1 Diff carriers
So ive been looking into building a rear end out of a 95 camaro, I got the rear end for cheap, but realize it wasnt a posi unit. Are the V6 Camaro rear ends the same as whats in the V8? Should i even bother with a auburn diff, or should i just look for a rear end out of a LS car?
Thanks,
Old 04-04-2010, 09:37 AM
Kevin01Z28's Avatar
Housings are identical for V6 and V8 cars.
Old 04-04-2010, 10:04 AM
01ssreda4's Avatar
thats correct. However, your axles for the V-6 may or may not be splined different from the new posi you get. You want to make sure the axles are correct or you may need V8 axles. Something to research.
