T56 problem please help!!!
I have a problem with my transmission and I hope someone can help me out. Well I was going for a drive and got on it in 2nd gear maybe to about 4.5K so when I got to the stop sign then the car wouldn't fully engage in any gear at all. Does anyone have a clue as to what would cause this? The shifter will like go in the slot for any gear but does push all the way into the gear. When I tried to to drive it and let off the clutch then it grinded. Any help will be much appreciated. Thanks alot
Your clutch is dragging during aggressive driving, most likely a hyd issue.. If you haven't done the drill mod yet, plan on doing it before you cause internal synchro damage. If you haven't flushed/bled your clutch hyd recently, plan on it and put some good hi-temp fluid in.
