subthump box installed
Old 04-20-2010, 10:25 AM
badbird5.7's Avatar
Default subthump box installed
finally got around to installing the box with two brand new kicker cvr's. kicker recommends a 2 week break in period for the subs so i haven't run them hard yet, but what i've heard so far the subs hit nice and clean.
Old 04-20-2010, 02:23 PM
bayer-z28's Avatar
12's? I got the same one.. But the Z28 logo..
Old 04-20-2010, 02:49 PM
99monguse's Avatar
How do the T-tops fit, do they make noise?
Old 04-20-2010, 05:01 PM
bayer-z28's Avatar
^ Nope... occasionally I (we, maybe) have to pull the box back toward the rear of the trunk to get the tops in. But they fit fine. I've had mine for about five years now.
Oh and to the OP: if your trunk won't close, lift the box up a hair till the latch resets or releases. It happens to me occasionally. The box puts pressure on the trunk latch. VERY mild nuisance if at all. The divider/block trunk thing fits back in too, so you can't even tell it's back there when the trunk is closed.
I think your Trans Am logo looks a helluva lot better than my piddly Z28 logo.
Mine
Old 04-20-2010, 07:38 PM
badbird5.7's Avatar
yes 12's,yeah no rattle from the tops i place a towel between the tops when i have them back there.Bayer did you buy the speakers from subthump?
Old 04-20-2010, 08:23 PM
bayer-z28's Avatar
^ no.. I got them from Crutchfield. Infinity Kappa Perfect 12's. As far as the tops, you don't put them in there glass against glass do ya? I place the inside of the glass against the body of the car for both tops.
And when it gets hot enough, that foam strip on the opening of the box comes off and leaves adhesive on your tops. Easy to get off with some goof-off or whatever.
Old 04-20-2010, 08:58 PM
badbird5.7's Avatar
no glass on glass,i put them in there the same way that you do
Quick Reply: subthump box installed
