General Maintenance & Repairs - Skip when coming to a stop?
View Full Version : Skip when coming to a stop?
TZ2884
04-25-2010, 01:33 AM
Recently I bought a 2000 b4c camaro, sometimes after running for a little while when I come to a stop the engine seems to be skipping. Once its skipping I can touch the gas pedal and it goes away. I was wondering what might cause this to happen. I was just hoping for some advice on where to start looking for the problem. Thanks in advance for any help.
thirdgengta350
04-25-2010, 02:51 AM
sounds like it could be a small vacuum leak. engine vacuum decreases as rpm's increase. it could also be a few other small issues but vac leak sounds most likely personally. check all your vac hoses etc for leaks and you may find your problem. good luck :chug:
TZ2884
04-25-2010, 12:47 PM
Thanks a lot. I'll have to check that out.
