Clutch Questions?
Clutch Questions?
While taking my son to Sonic to get milkshakes my 10 y/o son asked what a holeshot was. Being excited to show him I attempted to power brake it instead for the extra smoke. Instead of the tires smoking my clutch did.
So the Car is my 2002 T/A 'vert 68k miles 100% stock paper filter.
The most I might ever mod it would be basic bolt-ons, which at this time I have no intentions of doing.
I am in the middle of buying a house so money is an issue.
Is it a possibilty that its the hydraulics(sp) or is it more than likely the clutch?
if it is the clutch what should I have replaced and what is a good clutch.
My brother has a LS7 clutch in his 05 GTO and loves it. But another guy took a dump on the LS7 saying it was junk.
Also whats a good price for a clutch job in my area?
Thanks alot in advance.
J
J
In drag racing, a "holeshot" refers to a victory in which a driver runs a quicker elapsed time (E.T.), but loses the race due to a slower reaction time at the start.
I run a Centerforce dual friction 12" corvette in mine - from Summit for 400 bucks. Replace your slave cylinder while your there. The clutch chattered for 500 miles - which is exactly what the paperwork said it would do. Its been grabbin good for 10k+ miles now and feels slightly stiffer than stock but grabs 200% better.
I am not sure about your area but labor should range from 275-400 depending on labor rate.
Hope this helps.
Hope this helps.
I would suggest a ls7 clutch setup. The ls7 clutch will drive like stock and hold better than your stock clutch. No need to get an aftermarket clutch if you a only planning on boltons.Also do the slave cylinder. It is best to replace now to prevent hydraulic problems later. The slave should be no extra labor to replace during the clutch. If you wait then the trans has to be pulled again to change it.
The slave is a must because it's a wear item. I didn't change my master, don't think you need to either. I'm very happy with my LS7 clutch.
SDPC has free shipping on clutches through the end of april:
https://ls1tech.com/forums/sponsor-s...ches-sdpc.html
I believe this is the LS7 clutch & flywheel kit you need:
http://sdparts.com/details/scoggin-d...center/sdls7ck
You can also call SDPC to ask them about it.
Moderator
is your clutch slipping now under normal daily driving?...if not then dont replace it
i would get a ls6 clutch set up like what you have in there now which will be fine and the pedal pressure will be just like it is now. Some like ls7 clutches some have issues with them with no reason behind it.
the slave and master..well if there isnt a problem then i dont see the need to do anything there personally, if your car was a pre 2001 then i would upgrade the hydralics(master and slave)
ls6 clutch kit is what you should get if your current clutch is slipping
Is there an advantage to getting the LS6 as opposed to the LS7?
Ok I took it out for a ride(Thanks Chef) and could only get it to slip once by dropping the clutch at 5000rpms in 6th gear @ 40mph and even then it caught and clunked my drivetrain. Also it didn't smell when I got back. Now it was only a 15 minute ride but it held.
I'm sure the clutch isn't a 100% nor would I try to power brake it again, but hopefully I can get a little longer out of it.
Could it be the hydraulics? or a combo of worn clutch and hydraulics?
Its probably a combo. I would just drive it until it gets bad.( as long as its not your daily)
Ya I just want to get past closing. I assume your gonna PM me how much that LS7 will run me? And when are you gonna update your progress on the Challenger R/T? Dying to what can be done with one of those.
