thumping noise from the rear-end. help needed
Everytime I shift, and let of the gas and then hit the throttle again, I get a thump noise from the rear end. Haven't lifted it up yet, but wanted to get your thoughts. I was thinking bushings or something. Thank you in advance for the help.
Mine had the SAME sound at 34k miles. It is currently getting motor mounts (which were flat broken apparently) and a diff mount. The shop says this will cure it all!!
They suggested Creative Steel for the mounts but as of now I have nothing to go on.
Graham
Graham
Definately the front diff bushing. My car just crossed 29K and has the same issue. I will be going with the CS motor, trans and diff bushing along with a Monster clutch and flywheel and Katech shifter soon. I already have the Spectre cradle bushings. That should cure what I hate most so far about this car. The shitty rubber filled driveline.
