thumping noise from the rear-end. help needed
Everytime I shift, and let of the gas and then hit the throttle again, I get a thump noise from the rear end. Haven't lifted it up yet, but wanted to get your thoughts. I was thinking bushings or something. Thank you in advance for the help.
![The Patriot !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_patriot.gif)
Mine had the SAME sound at 34k miles. It is currently getting motor mounts (which were flat broken apparently) and a diff mount. The shop says this will cure it all!!
They suggested Creative Steel for the mounts but as of now I have nothing to go on.
Graham
Graham
Definately the front diff bushing. My car just crossed 29K and has the same issue. I will be going with the CS motor, trans and diff bushing along with a Monster clutch and flywheel and Katech shifter soon. I already have the Spectre cradle bushings. That should cure what I hate most so far about this car. The shitty rubber filled driveline.
