A.I.R. Pump
A.I.R. Pump
my air pump maybe going out cause when the car has been sitting for about 45min to a hour after its been ran on start up it sounds like a spaceship or something for a min before the sound goes away. is the air pump needed on the cars? can i delete it or will it mess up my egr system?
tho i see you are living in the wonderful land of california.....so this option may not be possible due to the inspections you must suffer thru..id get block of plates and sandwich them between the air tubes on the manifolds and egr then turn the codes off that way everything appears to be "tree friendly"
goes disabling the egr creat any time of power since hot exhaust gases arent being put back into the engine or no? i have the stock ls1 manifold but dont have the money for an ls6 at the time so i just cut the down tube to make it flush with the top of my manifold
