Problem With Raptor Shift Light!
The shift light lights up so it's recieving power but it is not lighting up at the desired RPM marker. I have connected the green wire to Pin #10 (white wire) on the red PCM connector. I set it correctly on 4 cylinder mode too. (Down, Up, Down)
The only thing that might not be correct is that I installed a Trick Performance Window Switch for my Nitrous kit along with it. I used a wire tap and both wires are joined together while being tapped into the white wire. Should I use a separate wire tap for the shift light?
Thanks!
Thanks!
Yea, you need to use separate wire taps. Also make sure you use the red ones (color coded for wire size: 22 gauge wire). If you use the blue ones they are too big and will cause an intermittent connection or no connection at all.
