air conditioner problems
you broke the seals loose so it is basicaly a leak. There is a single bolt in the back of that double line block and 2 ruber type seals that you can get from GM. You will need those and maybe some oil for it if any leaked out. Refill and should be fine. Be sure to clean real good around that block before you open it up or you can kiss the compressor goodby.
