Monster flywheel pressure plate bolt size??
Old 05-18-2010, 01:55 PM
SSmiley1906's Avatar
Default Monster flywheel pressure plate bolt size??
For those running a monster clutch flywheel do you reuse the original pp bolts or are they a different size? I had a Ram flywheel on that needed a different size bolt so now I need some clarification as to what to order. Thanks
SSmiley
Old 05-19-2010, 03:08 PM
texas82blazer's Avatar
They use the factory size bolts from GM.
Old 05-19-2010, 03:56 PM
nmass399's Avatar
I suggest ordering some arp pressure plate bolts and flywheel bolts to go with it just for added insurance and use threadlocker for peace of mind. Thats what i did for mine.
Old 05-19-2010, 04:05 PM
Many thanks, will be ordering arp's for both the flywheel and the pp. Also a new timing chain and oil pump to go with the ms4 install. Gotta get this **** done, Carlisle is looming closer by the day lol.
Old 05-19-2010, 05:30 PM
djfury05's Avatar
Monster recommends not using ARP's bolts for the pressure plate actually.. Call Steve he'll tell you.. just get new GM pressure plate bolts u'll be fine
Old 05-19-2010, 05:40 PM
nmass399's Avatar
Not sure what difference it would make using arp bolts, they are just as strong as stock and should be stronger. I can look and see what the difference is by eye since i got the transmission out. Only if they are longer or some difference in the bolt head.
Old 05-19-2010, 06:23 PM
djfury05's Avatar
dunno, just what Steve said, maybe they're overkill?
Quick Reply: Monster flywheel pressure plate bolt size??
