Battery Draining in GF's Tiburon (Car Audio Question)
She has the stock head unit and stock door/rear speakers. One PPI 5440 amp pushing one JL audio 10" sub. Im not sure where the remote wire is ran from (Best Buy did the install) but when I turn the car off, the amp stays turned on. This obviously drains the battery. What would be causing this, and where can I run the remote wire to avoid this problem? Thanks in advance.
I'm sure they tagged the remote behind the radio, same place they would have tagged the line out converters. There should be a constant wire back there (that they used) and also an accessory wire (that they should have used). They need to disconnect that wire and put it on the right one! I would take it back and make them do it and then never take it to that place again. That is a BIG TIME rookie mistake...
2007 Hyundai Tiburon Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Pink/Black
Car Stereo Dimmer Wire: Green
Car Stereo Antenna Trigger Wire: White/Black
Car Stereo Amp Trigger Wire: White/Orange
Car Stereo Amplifier Location: Amplifier is located below the drivers side rear speaker (behind the trim).
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White
Left Front Speaker Negative Wire (-): Brown
Right Front Speaker Positive Wire (+): Black
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Blue
Left Rear Speaker Negative Wire (-): Red
Right Rear Speaker Positive Wire (+): Green
Right Rear Speaker Negative Wire (-): Orange
I'd would use the "Car Stereo Amp Trigger Wire: White/Orange" which would give you more control over when the amp is on/off by linking it to the radio and not the ignition.
EDIT #1: Assuming this is a +5v voltage that is what I believe most after market amps use for the remote-on feed.
EDIT #2: Go back to Best Buy and tell them to fix it.
David
David
