Battery Draining in GF's Tiburon (Car Audio Question)
Old 05-18-2010, 06:12 PM
Charlie Hustle's Avatar
Default Battery Draining in GF's Tiburon (Car Audio Question)
She has the stock head unit and stock door/rear speakers. One PPI 5440 amp pushing one JL audio 10" sub. Im not sure where the remote wire is ran from (Best Buy did the install) but when I turn the car off, the amp stays turned on. This obviously drains the battery. What would be causing this, and where can I run the remote wire to avoid this problem? Thanks in advance.
Old 05-19-2010, 09:08 AM
slow96z's Avatar
I'm sure they tagged the remote behind the radio, same place they would have tagged the line out converters. There should be a constant wire back there (that they used) and also an accessory wire (that they should have used). They need to disconnect that wire and put it on the right one! I would take it back and make them do it and then never take it to that place again. That is a BIG TIME rookie mistake...
Old 05-19-2010, 09:09 AM
CajunZ's Avatar
remote wire needs to be on the fuse box on the ignition fuse. thats what i have always done
Old 05-19-2010, 09:40 AM
BT03mach-1's Avatar
2007 Hyundai Tiburon Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Pink/Black
Car Stereo Dimmer Wire: Green
Car Stereo Antenna Trigger Wire: White/Black
Car Stereo Amp Trigger Wire: White/Orange
Car Stereo Amplifier Location: Amplifier is located below the drivers side rear speaker (behind the trim).
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White
Left Front Speaker Negative Wire (-): Brown
Right Front Speaker Positive Wire (+): Black
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Blue
Left Rear Speaker Negative Wire (-): Red
Right Rear Speaker Positive Wire (+): Green
Right Rear Speaker Negative Wire (-): Orange
Old 05-19-2010, 09:53 AM
FireHawk178's Avatar
I'd would use the "Car Stereo Amp Trigger Wire: White/Orange" which would give you more control over when the amp is on/off by linking it to the radio and not the ignition.
EDIT #1: Assuming this is a +5v voltage that is what I believe most after market amps use for the remote-on feed.
EDIT #2: Go back to Best Buy and tell them to fix it.
David
Old 05-19-2010, 09:56 AM
TAtoad's Avatar
they probably ran the remote to the wire/fuse which runs power for the radio's memory, switch it over to the one which actually powers the radio
Old 05-19-2010, 03:08 PM
Thumbs up
Thank you guys for all the responses.
Quick Reply: Battery Draining in GF's Tiburon (Car Audio Question)
