How to determine stall of torque converter?
Bought a used 2000 Camaro. Was told the car has a stall converter(PINK IN COLOR) but the previous owner did not what size.
Flashes to about 4000rpm WOT.
My guess is the converter is a vig 3600? Any guesses? Any way to determine stall speed without a transbrake?
The best way is with a trans-break, flip the switch and floor it. But since you don't have a trans-break you can use the flash RPM. If it is flashing to 4000, then it is a 4000 stall in your setup. Converters stall will change based on input power. Hope this helps.
Chris
Chris
The following users liked this post:
Chiesa12 (10-28-2020)
