Notices
WTB: NP261HD Transfer Case!
Old 05-21-2010, 10:51 AM
SpecV44's Avatar
Default WTB: NP261HD Transfer Case!
need a NP261HD transfer case for my fullsize (2003 Silverado 2500HD 4x4). Looking ASAP! PM me as this thread will probably get lost.
Old 05-21-2010, 05:49 PM
andrew69_04's Avatar
good luck. i ended up having to buy a reman when mine went out. sad part is, it had a 12 month unlimited mileage warranty with it and 15 months later it started going bad again.
Old 05-22-2010, 09:53 PM
SpecV44's Avatar
what went out on it? It seems a bearing went bad, then clogged up the oil pump pickup, then the shaft got overheated and destroyed the rest of the pump.
Old 05-23-2010, 09:26 AM
thesource's Avatar
These latest generation GM transfer cases are junk. They are designed to take a ****. I cannot tell you how many of them I have rebuilt from them wearing holes in the rear case and burning up.
Old 05-24-2010, 07:53 AM
SpecV44's Avatar
yeah, that is what I have heard. Unfortunately, it doesnt seem like that happened to me. It seemed to have developed a leak up on the passenger's side, causing a low fluid issue and burned up the bearings. Didnt see a hole in the case.
Old 05-24-2010, 08:11 PM
thesource's Avatar
Trust me, they are there. Usually its three small pin holes. You will notice on the back side of the transfer case, the dirt and gunk will cover the case. This is where the fluid was leaking and the dirt was sticking to it.
Old 05-25-2010, 12:34 PM
SpecV44's Avatar
yeah, i believe ya. trust me, the thing is only good as a core. it would cost me more to rebuild it than to get a rebuilt one. chain is sloppy, bearings are gone, pump is broken ON the shaft, bearings welded to the shaft, started eatting case, etc etc.
Old 05-25-2010, 09:58 PM
thesource's Avatar
It probably isn't even a rebuildable core if its that bad. I've seen some really burned up in the past.
Old 05-28-2010, 08:35 AM
SpecV44's Avatar
bump, still looking
Old 06-04-2010, 08:32 AM
SpecV44's Avatar
bump. Seems like I will have to go with a rebuilt one off ebay.
Old 06-24-2010, 12:49 PM
SpecV44's Avatar
bump, just checkin
Quick Reply: WTB: NP261HD Transfer Case!
