What spline is the viper shaft?
Old 05-24-2010, 11:00 AM
robsquikz28's Avatar
Default What spline is the viper shaft?
Im trying to figure out if a stock driveshaft will work? Is it the same as a stock t56?
Old 05-24-2010, 01:06 PM
bigj2717's Avatar
You need a different yoke on the drive shaft. Viper output shaft is 30 spline stock f-body is 27. I believe that Tick will sell just the yoke you need
Old 05-24-2010, 09:24 PM
NVR_SPDS's Avatar
+1 ^^ When i went with my RPM built T56 (Viper spec) i got a yoke for the stock driveshaft. Youll need the yoke, and a conversion u joint. I also had my driveshaft balanced afterwards, just to make sure it was right.
Quick Reply: What spline is the viper shaft?
