'04 GTO LS1 and T56 in a '66 A Body-Which Shifter?
Old 05-27-2010, 10:39 AM
mrgto's Avatar
Default '04 GTO LS1 and T56 in a '66 A Body-Which Shifter?
I know the shifters are a bit different from the F Body T56 and the GTO T56. As far as location, is this an ideal tranny to use in a A Body? Anyone ever use a GTO T56 in a GM A Body? Thanks.
Old 05-27-2010, 09:14 PM
lizeec's Avatar
Default 1966 gto
I installed a 2006 GTO LS2 & T56 into my 1966 GTO, I did have to modify the transmission tunnel with a "T" cut but I left the stock shifter in its original place it seems to be about 4-6" further back than a similar "F" Body T56 transmission but after I put the seats in and sat in it and shifted through the gears it felt pretty much the same as when I had the 389 and Muncie 4 speed, I tried to load some pictures but it kept telling me they were too big, I have a few pics if you want pm me your email address and I can send them to you.
Old 05-28-2010, 10:06 AM
mrgto's Avatar
Lizeec, thanks. my email is mrgto455@yahoo.com
Much appreciated.
Old 08-04-2010, 08:49 PM
Deserttaco's Avatar
Did you ever find a shifter that will work with your setup? I'm installing a GTO T-56 into my 70 Chevelle, and my shifter was damaged, so I'm going to have to replace it anyway. The aftermarket GTO shifters are Stupid expensive, and I've noticed that the F-body shifters are quite a bit cheaper, and I'm wondering if I can use an F-body shifter in my GTO Trans?
Steve
Old 08-04-2010, 09:49 PM
rotor vs. piston's Avatar
Yep, you just have to get the correct ball cup for the f-body shifter. I can't remember where I got mine off hand, but it was ~$30.
Quick Reply: '04 GTO LS1 and T56 in a '66 A Body-Which Shifter?
