Fell just short of being in the 500 club (Warning Cobra inside)
Fell just shy of 500rwhp on Stock blower with alittle metal removed
Okay the setup is very close to stock,and I must say im VERY impressed with the numbers on a conservative street tune with ONLY a 2.93 upper seeing about 10.5-11psi (4lb Lower had to be ditched due to fuel pump duty cycle ) Ported and welded plenum,Ported Eaton and Ported Throttle body.A Cold air kit,H-pipe and flowmaster catback laid down right under 500rwhp :dancenana:
http://www.youtube.com/watch?v=wqaL5i6BcTI
A boost a pump will fix that issue no problem! Throw that 4lb back on there and you will pick up 30-40whp.
I made 533/535 on a ported eaton with a 2.76/2lb combo. Only had a BAP and a MAFia for fuel mods. But that was 5 years ago.
