5.3 into a 2002 camaro 3800.
Old 05-28-2010, 11:28 PM
dangerjakeray's Avatar
Default 5.3 into a 2002 camaro 3800.
Ive got the engine in, mounts connected and everything done but the wiring. Ive tried to connect the 5.3 harness to the 3.8 harness that runs the lights and radio and such. Ive also tried to hook up the 5.3 harness to the v6 fuse box for the ignition. So far all that im able to get is the normal beeping sound when I put the key into the engage position. Any Ideas or better yet has anyone done this swap. Im not electrically inclined so any help would be very welcomed/
Old 05-28-2010, 11:49 PM
ge_forcez22's Avatar
http://www.lt1swap.com/wiringharness.htm
this site will have all the info you will need.
Old 05-29-2010, 11:20 AM
TheAntiRice's Avatar
you will need to purchase the relay harness from a 2002 ls1 i know that will work
