GTO Rim Size
Here are my CCW specs and they are perfect. From these you can judge what will work.
19x8.5 +42mm front
19x10 +54mm rear
Center bore= 69.6mm
12mm studs
Lug pattern= 5/120mm
19x8.5 +42mm front
19x10 +54mm rear
Center bore= 69.6mm
12mm studs
edit: and if you haven't already, go ahead and grind or roll your fenders, just be careful if you grind, there are two body welds that you don't want to cut out, I had mine done by a competent shop just to make sure, as it is pretty thick.
Yeah, I'm gonna be using the 5 x 4.75 bolt pattern, so I was planning on using the ARP Studs anyway. :-)
Whats the diameter of the GTO hub?
The wheels I'm looking at have a center bore of 70.70mm. Wanna make sure the center bore is ATLEAST bigger than the cars hub.
EDIT: I'm seeing 69.5 Hub diameter(is this correct?). with a difference of 1.2mm... Should I care to get hub rings? Are they even available in such a miniscule slimness?
EDIT2: Yeaaa.... That leaves like a 1/42-inch of a tolerance between them. Sounds peachy to me! :-)
