El Torro Idle
Old 06-02-2010, 11:47 AM
00cls1camaross's Avatar
Default El Torro Idle
What is your El Torro idle set at? I just ordered the cam and I want my car to lope pretty hard.
I was thinking maybe setting idle at 800. Thoughts?
Old 06-02-2010, 11:53 AM
SSmoken's Avatar
mines 900 but still needs more tuning and doesnt always like to idle there all the time.
Old 06-02-2010, 12:00 PM
Gaunt's Avatar
Get that bitch tuned Dakota!
For what it's worth, my cam is close to the el torro and it sits around 850-900ish.
Old 06-02-2010, 03:05 PM
who tuned your car ssmoken?
i will get it tuned, i just want it to idle real low
Old 06-02-2010, 03:45 PM
SOMbitch's Avatar
950 and still choppy as hell
Old 06-02-2010, 04:17 PM
SSmoken's Avatar
Just a local guy. As soon as my heads get here it's going on the dyno to get finished up.
Old 06-03-2010, 01:10 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
I think it has an 8° valve overlap. If you want a comparison I had a 15.5° overlap on my 244/248 cam and it loped really hard.
Old 06-03-2010, 05:52 AM
I know it doesn't have a lot of overlap, that is why I wanted to set the idle real low so it would lope hard. I dont DD the thing so I dont really care if it has trouble idling
Old 06-03-2010, 05:57 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
You will care when it dies at every stop light!
I had my 244/248 cam idle set to 1100 and it still had a pro stock idle.
228R is set to 900.
Old 06-03-2010, 07:40 AM
Nitroused383's Avatar
You don't set your idle for sound. You set it for where the cam has decent vacuum. 850-950 rpm is probably about right. I have played with my idle quite a bit from 1000 rpm down to 600 rpm and it reallys doesn't lope any harder the lower you go. I prefer the way it sounds around 900, a nice quick chop. It will lope pretty good anyways, here is my 224 cam idle @ 900 rpm, yours will sound similar.
http://www.youtube.com/watch?v=Ed8s0ovoQDU
Old 06-03-2010, 10:04 AM
SSmoken's Avatar
228R is set to 900.
yeah, my car dies quite a bit. if it ever stays idling at 900 though its fine.
Old 06-03-2010, 10:31 AM
LSX Mechanic
Damian's Avatar
The El Torro needs a 900-950 rpm idle and correct MAF/VE/RAF calibrations. The driveability of this cam is less than impressive and requires some extra elbow grease to tune properly.
Old 06-03-2010, 01:32 PM
Why is the cam not easy to drive on city streets? I didnt think it was that aggressive of a grind
Old 06-03-2010, 02:11 PM
SOMbitch's Avatar
Mine drives GREAT once it warm. Doesn't cut off, minimal surge etc...more power EVERYWHERE. Cold start SUCKS though....
Old 06-03-2010, 02:45 PM
No reason cold start should suck at all, do you have hptuners or anything? I could fix that for you.
Old 06-03-2010, 08:39 PM
LSX Mechanic
Damian's Avatar
What does it do during cold starts?
Because it's on a 230 cam on a 111LSA.
Old 06-03-2010, 10:43 PM
It has 2 degrees of advance ground into it, should that be 113
Old 06-04-2010, 03:58 PM
SOMbitch's Avatar
Damien, It just knocks off w/o a little throttle and hunts for idle. After about a minute all is good.......
Old 06-04-2010, 04:04 PM
LSX Mechanic
Damian's Avatar
No. 2 degrees of advances means it's bringing the intake closing point or "ICL" down to a 109. Advance does not change the LSA, it changes intake closing.
The El Torro is a 111+2 which means it's a 111LSA/109ICL.
