Gasket maker on new water pump gaskets? Switch from dexcool?
Old 06-05-2010, 10:00 PM
Tuffguy610's Avatar
Default Gasket maker on new water pump gaskets? Switch from dexcool?
Hey guys,
I'm doing a water pump replacement tomorrow and was wondering two things (as mentioned above):
- Do I need to use RTV gasket maker on the gaskets? These LS1 gaskets seem to be different than a typical application.
- Can I switch from dexcool to traditional ethylene glycol? Are there any adverse effects?
Also, if theres any other tricks for installing a water pump let me know. Thanks!
Old 06-06-2010, 12:21 AM
sjsingle1's Avatar
GM gaskets are metal and have a rubber insert........no rtv needed......why switch???
Old 06-06-2010, 12:36 AM
eseibel67's Avatar
No RTV, gaskets seal beautifully right out of the box.
Leave the Dexcool. You could switch to green, but there is no advantage.
Water pump change on LS1 is very easy.
Old 06-06-2010, 03:55 PM
Tuffguy610's Avatar
Thanks for the advice guys. I just did it this morning. The leak was definitely coming from the gaskets as the rubber on the old gaskets fell off the metal upon removal. We filled with dex cool and it seems good to go.
Quick Reply: Gasket maker on new water pump gaskets? Switch from dexcool?
