408 stroker dish pistons for L92 heads???
Old 06-08-2010, 08:31 PM
general23cmp's Avatar
Default 408 stroker dish pistons for L92 heads???
Trying to find some dish pistons for a 4.030" bore, 4" stroke, iron block that will work with L92 heads. Seems simple enough, but either the bore is wrong or they don't specify they will work with L92 heads when I search online.
Help....
Didn't know the best forum since it spans a few....figured this was best chance.
Old 06-09-2010, 04:58 AM
LS1MCSS's Avatar
Call TSP and talk to them. I think the piston in the link is cut for L92 valve reliefs.
http://www.texas-speed.com/shop/item...d=114&catid=38
Old 06-09-2010, 08:32 AM
bww3588's Avatar
Wiseco makes a nice L92 based piston in 4.030 bore and 4 inch stroke. check out their website.
Old 06-09-2010, 10:09 AM
thanks. May be, but it will take a call since it doesn't say it will work on L92.
Old 06-09-2010, 11:13 AM
Thanks. I like the K456X3. It's for a 4.030 bore and 4" stroke with a -20cc dish. Wonder why the ring number for it (4032GFX) is for a 4.032" bore? I thought when a piston manufacturer says a piston is for a specific bore, that was what the block should be machined to.
Quick Reply: 408 stroker dish pistons for L92 heads???
